01-12-2017 08:28 AM - edited 03-11-2019 12:21 AM
Long title for the problem. We recently installed new SSL Certificates on our ISE servers Version 1.4 and put patch 10 on the ISE servers as well. The certificates are from inCommon. Since the patch and ssl certificate installs, we are having issues with some of our Apple devices on wireless. The clients attempt to connect 3 or 4 times, actually authenticate, get and ip address and then drop the session. Not all clients and not all apple devices. Has anyone seen or experienced this, and if so, what the solution may be. TAC as been working on this for a month and we are stilling having this issue. Below is what I get from ISE
se-psn2 | |
Event | 5440 Endpoint abandoned EAP session and started new |
Failure Reason | 5440 Endpoint abandoned EAP session and started new |
Resolution | Verify known NAD or supplicant issues and published bugs. Verify NAD and supplicant configuration. |
Root cause | Endpoint started new authentication while previous is still in progress. Most probable that supplicant on that endpoint stopped conducting the previous authentication and started the new one. Closing the previous authentication. |
01-12-2017 10:07 AM
I have seen this before and it was due to a bug with the WLC code. What version are you running on your WLC?
Also, do you have "AES Keywrap" enabled under the SSID?
Thank you for rating helpful posts!
01-12-2017 10:33 AM
AES keywrap I don't see under the ssid, but I b believe that it would not checked.
We are running version 8.2.130.0
01-12-2017 11:07 AM
Sorry, this setting is under the AAA Radius server configuration. Please check again.
Also, is there a specific reason(s) that you are running 8.2.130 instead of the recommended 8.0.140.0 version? I am not a wireless guy but I have heard from several users that the 8.2 train has been very problematic.
01-12-2017 11:15 AM
AES keywrap is not enabled. We moved to the 8.2 because we are installing 3802i ap and you need 8.2 for them.
I am seeing this issue on one controller that is still on 8.0.133.0 also.
01-15-2017 12:47 PM
Below is from a debug, where the client is getting a COA de-auth after an ipv6 request.
