Cisco ISE , domain Users mapping with specific Domain Machines
aslam.bajwa
Level 3
Level 3
Hi All ,
we have cisco ISE distributed deployment , and we are using EAP Channing for authentication ,
now my scenario is we have one domain Machine and two Domain Users ,
when users A login on the machine its working fine and get complaint , but when user B try to login on the same machine he can successfully login  but AnyConnect Agent showing policy server not found and system scan not working ..
on Iive logs its show Posture Pending ...
can any one help on this ….. regards
Mike.Cifelli
I assume you have changed the registry setting so that NAM allows multiple users to be logged on. How are your client provisioning policies set up? I am thinking you potentially may not be hitting the respective one needed to run the posture checks for user B. Have you tested a full blown user A logoff, then logon with user B? Same results?
