07-03-2013 04:16 AM - edited 03-10-2019 08:36 PM
We are running the cisco ise 1.1.3 and configured for the Dot1x and MAB authentications. PC's are getting access through MAB while Dot1x failing again and again. But, sometime, same PC is getting authenticating via Dot1x. Connectivity is intermittent. Also, sometimes, stucks longer in Posture
We have three different switches at the moment with the latest IOS version.
1) WS-C4507R-E = 15.1(2)SG,
2) WS-C3560-48PS = 12.2(55)SE7
3) WS-C3750X-24P = 15.0(2)SE1
Could you anyone pitch the idea? or advise about the latest IOS for the switches.
Let me know, if you need more information.
Mubahser
07-03-2013 06:02 AM
It seems your PCs are failing dot1x and also failing MAB authentication, the switch by default will start the process again and will again fail dot1x and MAB authentication, and so on.
It will be helpful to see the logs from both the switch and the radius servers (i take it is ACS or ISE). Also the configuration of the radius server.
07-04-2013 02:06 AM
Please follow up the link bwlow whoich ma y solve your query:-
http://www.cisco.com/en/US/docs/security/ise/1.0/troubleshooting_guide/ise10_tsg.html#wp185386
