Cisco ISE Guest Settings Issue
Mark Massheder
Hi All,
Hopefully this will be a quick fix.
I'm unable to remove the San Jose from Locations within the Guest Settings and receive the following error "Failed to delete locations : San Jose: Location referenced by another configuration". I've attached the settings and error for reference.
I've checked all settings within the Guest tab and removed any reference to San Jose, unless it is referenced in the Setup Wizard which i wasn't involved in where else could this be referenced and how to remove please? It's only cosmetic but for creating guest accounts it is frustrating as the location shows San Jose when they are in fact located in the UK. I'm running Cisco ISE version 1.3.
Mark
Venkatesh Attuluri
its a bug
CSCus25245
Description
Symptom:
In ISE 1.3, under Guest Settings - > Location and SSID, we are unable to remove the San Jose default location.
We get the error that it is referenced by some other object.
Conditions:
ISE 1.3 - Looking to remove the San Jose default location.
Venkatesh Attuluri
its a bug
CSCus25245
Description
Symptom:
Conditions:
Hi Venkatesh,
Thanks for clarifying its a bug I thought I was going mad or the setting was hidden!
kind regards
Mark
Kindly go through the attached configuration.
