10-06-2019 03:00 AM
Hi All ,
we have cisco ISE 2.4 , Distributed deployment with Wired , Wireless and VPN.
currently we have Pre-Posture configuration ( i.e. we have to enable http server on Cisco Switches for redirect ) .
can we move to Post-posture configuration ? currently we have more then 800 hundred users in production ..
what cisco best practices says ? should we go for Post-Posture configuration
Regards ,
Solved! Go to Solution.
10-06-2019 04:21 AM
10-06-2019 03:13 AM
I assume you referring to post ISE 2.2 posture which does not require a redirect? You need to pre-provision the AnyConnect client and the ISEPostureCFG.XML configuration file, this need to be configured with call home list in order to start the posture process. Reference here.
10-06-2019 03:43 AM
Hi RJI ,
many thanks for your reply .
correct , i am asking about post ISE 2.2 posture , but my man concern is what is the cisco best practices and recommendations.
Pre-Posture or Post posture
10-06-2019 04:21 AM
10-07-2019 09:44 AM
