Usually a new box delivered from cisco is ready with per-installed software and you do not need to change anything in CMOS setup for boot up sequence or software installation configuration.
We have revived 2 boxes first is working fine second boxes is unable to boot from per-installed ISE software .When i try to install software using boot able USB drive facing an error that no partition available copy the software into hard drive than try to reinstall the software again.
Moreover the box which is having software installation problem does not have software raid controller installed "SCU embedded raid controller" is missing from the box.
I might need to create this software RAID controller but could not find the way to do it.
Any help will be highly appreciated.
