Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco ISE session Licenses - consumption model
I see the 2018 ordering guide is now licenses per session. Can anyone explain how the session consumption work? is it the same as the per device/per user  count that uses a Base/Plus or APEX depending on the feature ? Thanks
2 Accepted Solutions
Damien Miller
ISE tracks endpoints/licensing by MAC addresses so it's not always as simple as user/device count. Licensing in ISE is based off of the active sessions count, and active sessions are dynamically tracked. If endpoint Y authenticates on wired, it will consume 1 base license. That authentication may leverage features that also require a plus and apex license, thus using 1 Base, 1 Plus, and 1 Apex at the same time. Where is gets complicated is if an endpoints drops off the network without notification getting to ISE. That active sessions will then be held for 5 days before being released.
Additionally, if an endpoint is connected to both wired and wireless at the same time, that will use licensing for both active sessions. ISE sees this as two devices because they have unique MACs.
Base license features:
Basic network access: AAA, IEEE-802.1X
Guest services
Link encryption (MACSec)
TrustSec
ISE Application Programming Interfaces
Plus license features:
Bring Your Own Device (BYOD)ā€”when consuming either a built-in or an external certificate authority
MSE integration for location services
Profiling and Feed Services
Adaptive Network Control (ANC)
Cisco pxGrid
Apex license features:
Third Party Mobile Device Management (MDM) integration
Posture Compliance
TC NAC
This document covers the usage of licensing and a few other scenarios I did not cover. These are just the three most common endpoint licensing categories.
https://www.cisco.com/c/en/us/td/docs/security/ise/2-4/admin_guide/b_ise_admin_guide_24/b_ise_admin_guide_24_new_chapter_0110.pdf
Damien Miller
ISE tracks endpoints/licensing by MAC addresses so it's not always as simple as user/device count. Licensing in ISE is based off of the active sessions count, and active sessions are dynamically tracked. If endpoint Y authenticates on wired, it will consume 1 base license. That authentication may leverage features that also require a plus and apex license, thus using 1 Base, 1 Plus, and 1 Apex at the same time. Where is gets complicated is if an endpoints drops off the network without notification getting to ISE. That active session will then be held for 5 days before being released.
Guest services
TrustSec
Cisco pxGrid
Posture Compliance
TC NAC
8 Replies 8
Francesco Molino
Consumption in ISE depends on your rules. If you authenticate a user, then the session is based on this user for this specific device. If he connects through a 2nd device, then a 2nd license consumed.
If you're authenticating the device, no matter how many users log in on this device, you will get only 1 session.
Is that clear?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Damien Miller
Guest services
TrustSec
Cisco pxGrid
Posture Compliance
TC NAC
Damien Miller
Guest services
TrustSec
Cisco pxGrid
Posture Compliance
TC NAC
Is there a way to adjust this to an hour or so?
No, the 5 day session timeout is not configurable in ISE.
   If you think about it, the problem is if users disconnect from the network in a not graceful manner; but for users that constantly reconnect, this 5 day limitation is not a limitation; you only run into issues, if you have within those 5 days many users that show up just once and they disappears.
Cristian Matei.
We are only using ISE for Anyconnect users authentication from the ASA using RADIUS protocol. It says we reached above 4000+ connections when we have less than 500 users. Its main purpose is just username and password auth.
jewfcb001
Level 4
Level 4
Hi Everyone .
I'm looking for same answer I think We have same issue. About Session per day Can i refer on current active session on Operation -> Report ?
