Highlighted
Beginner
Cisco NAC CAM issue 3315 Series
When booting up it gets stuck at:
SELinux: Disabled at runtime.
type=1404 audit(1363211439.273:2): selinux=0 auid=4294967295 ses=4294967295
Please I need some advice. Attached is a pic I took
3 REPLIES 3
Advocate
Luis,
You may need to reimage this box as something must be corrupt.
http://www.linuxforums.org/forum/red-hat-fedora-linux/161130-boot-hangs-after-selinux-disabled-runtime.html
Tarik Admani
*Please rate helpful posts*
Tarik Admani
Beginner
Yes, that was our first thought, but we didn't want to re-image it. I was hopping someone else had fixed it before.
Question:
1- If I reimage it, will I loose the Serial Key and Activation?
2- If it loses the activation key, how can I recover it back (as a reference I didn't buy the equipment originally, therefore I don't have access to the SmartNet of this equipment)
Advocate
Re: Cisco NAC CAM issue 3315 Series
Do you have your clean access manager in a failover cluster? If so, is this the secondary manager?
Re-imaging will cause you to lose everything unless you have a backup (even then I do not think your licenses are backed up). It maybe worth you effort to reach out to the original owner to have the license files sent back to you.
Tarik Admani
Tarik Admani
