Cisco NAC CAM issue 3315 Series
lmramos89
When booting up it gets stuck at:
SELinux: Disabled at runtime.
type=1404 audit(1363211439.273:2): selinux=0 auid=4294967295 ses=4294967295
Please I need some advice. Attached is a pic I took
Tarik Admani
Luis,
You may need to reimage this box as something must be corrupt.
http://www.linuxforums.org/forum/red-hat-fedora-linux/161130-boot-hangs-after-selinux-disabled-runtime.html
Tarik Admani
*Please rate helpful posts*
Yes, that was our first thought, but we didn't want to re-image it. I was hopping someone else had fixed it before.
Question:
1- If I reimage it, will I loose the Serial Key and Activation?
2- If it loses the activation key, how can I recover it back (as a reference I didn't buy the equipment originally, therefore I don't have access to the SmartNet of this equipment)
Do you have your clean access manager in a failover cluster? If so, is this the secondary manager?
Re-imaging will cause you to lose everything unless you have a backup (even then I do not think your licenses are backed up). It maybe worth you effort to reach out to the original owner to have the license files sent back to you.
Tarik Admani
