Cisco NAC Profiler modules are stopped and Stalled
Hi Everyone,
My Cisco NAC Profiler got stuck and showing the current modules are Stalled and Stopped. They were working perfectly fine till yesterday....
Cisco NAC Manager SW = 4.9.1
Cisco NAC Server SW = 4.9.1
Cisco NAC PRofiler = 3.1.1.18
The output commands on server are
service collector status
Profiler Status
   Version: Collector-3.1.1_18
  o Server      Not Installed
  o Forwarder   Running
  o NetMap      Running
  o NetTrap     Running
  o NetWatch    Running
  o NetInquiry  Running
  o NetRelay    Running
service collector verify
Collector Network Configuration
Collector Name    = NAC-CAS-YB01
Connection Type   = server
Listen on IP      = 10.115.199.200
Network IP ACL
127.0.0.1
10.113.199.203
Port Number       = 31416
Encryption type   = none
Shared secret     =
[root@NAC-CAS-YB01-01 ~]#
On Profiler Side is as follows;
[beacon@NPS-1 /home/beacon]# service profiler status
Profiler Status
   Version: Profiler-3.1.1_18
  o Server      Running
  o Forwarder   Not Installed
  o NetMap      Not Installed
  o NetTrap     Not Installed
  o NetWatch    Not Installed
  o NetInquiry  Not Installed
  o NetRelay    Not Installed
Any idea or comment plz.
Mubasher
Tarik Admani
The information you posted looks fine, the profiler will not have the collectors installed and the collectors show all services running and the server as not installed because it isnt the profiler.
Here is an example for reference:
http://www.cisco.com/en/US/docs/security/nac/profiler/release_notes/310/310rn.html#wp159659
Tarik Admani
*Please rate helpful posts*
