Highlighted
Enthusiast
Cisco Secure ACS 5.2 Patch Installation Issue
I am trying to apply patch 5.2.0.26.10 to a newly installed Cisco Secure ACS Server.  When I run the acs patch install command it fails.
Here is my repos config:
repository Update
  url sftp://10.134.52.115/
  user id4sftp password removed
sh repo Update - output
5-2-0-26-10.tar.gpg
Command Execution:
acs patch install 5-2-0-26-10.tar.gpg repository Update
Response:
Failed to copy file '5-2-0-26-10.tar.gpg' from repository Update
(Error -306)
% Error: patch install 5-2-0-26-10.tar.gpg from repository Update - transfer failed (code 1)
Debugs:  (debug transfer 7, debug copy 7) Response
6 [20989]: transfer: cars_xfer.c[47] [admin]: sftp copy in of 5-2-0-26-10.tar.gpg requested
6 [20989]: transfer: cars_xfer_util.c[480] [admin]: resolved server to 10.134.52.115
7 [20989]: transfer: cars_xfer_util.c[487] [admin]: copying /home/id4sftp/5-2-0-26-10.tar.gpg from remote server: 10.134.52.115
7 [20990]: transfer: sftp_copy.c[70] [daemon]: Executing SFTP command: /usr/bin/scp -o StrictHostKeyChecking=no id4sftp@10.134.52.115:/home/id4sftp/5-2-0-26-10.tar.gpg /opt/CSCOacs/patches/5-2-0-26-10.tar.gpg
3 [20989]: transfer: sftp_copy.c[137] [admin]: sftp_copy ERROR: timeout!
(Error -306)
3 [20989]: transfer: sftp_copy.c[230] [admin]: sftp_copy ERROR: command execution failed
Thank you very much for your assistance
David
Everyone's tags (6)
5 REPLIES 5
Advocate
There is a bug in the 5.2 code so that when a sftp file transfer takes over 60 seconds it will cause errors, can you try with ftp?
Tarik Admani
*Please rate helpful posts*
Tarik Admani
Enthusiast
I will work on trying FTP now.  Are there any other options?  I am running this in a VM instance, so not exactly sure if I can create an ISO and try to copy from it over to the server then run it.
Thank you
Advocate
Your best bet is to use filezilla server and run it on your host machine that has acs connectivity.
Tarik Admani
Tarik Admani
Enthusiast
Tarik,
Thank you very much for your replies.
I was able to perform the update via FTP.
Thank you again
Beginner
I have this problem also,
I have this problem also, however, I am not allowed to use ftp. I have to use sftp, any help with this will be appreciated.
Response:
(Error -306)
