Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
338
Beginner
Cisco Switch 3560 Wired portal redirect to ISE/Clearpass
Dear Experts,
I need some help here to configure wired 802.1x on one part of our campus. We are currently evaluating Clearpass/ISE (on our own and some help from partners). Switch that I am using in my lab is 3560-8pc running 12.2
Can someone pass me the exact configuration that is required for switch to redirect the user to CP/ISE captive portal page that is received via Radius attribute?
2 REPLIES 2
VIP Advocate
Re: Cisco Switch 3560 Wired portal redirect to ISE/Clearpass
I usually follow the guide given below for Wired switch configuration for ISE setups:
https://communities.cisco.com/docs/DOC-68171
The document is usually updated when new features releases come out.
The main sections required for redirect apart from basic Radius setup are the redirect ACL itself, http server config and Radius dynamic authorization.
Same should be true for ClearPass also as long as they send the same Radius attributes back.
Highlighted
Beginner
Thanks Rahul,
Is there any document that also describes this process in general also? I am having difficulty putting all the pieces together as to how a redirect works.
