Beginner
Cisco TrustSec with WCCP and Load Balancers
I am currently deploying TrustSec in an environment and I am looking for documentation for how to deal with Bluecoat Proxies,  SilverPeak WAN Optimization using WCCP and Citrix NetScaler Load Balancing. I think SGT Caching is answer but looking for other opinions as well as documentation that may show/explain how this works. Has anyone experienced this?
1 ACCEPTED SOLUTION
Highlighted
Re: Cisco TrustSec with WCCP and Load Balancers
Derrick,
You are spot on with SGT Caching. That would strip out the SGT while entering the blue-coat proxies or SilverPeak WAN and will coming out would reattach the tag. We don't have specific deployment guide on this. But if you would like I can share a slide with you on Spark.
4 REPLIES 4
Highlighted
Derrick,
Beginner
Hi Karthik,
Thank You for the fast response. If you have a slide that would really help. I know that this works but I am not able to explain the order of operations to the other engineers. Anything you have would be helpful. So, that slide would be great. Do you need my E-mail address? Thanks!
I checked on Spark but couldn't locate you. Could you provide the email address? I can send that offline.
Beginner
