02-02-2016 04:25 AM - edited 03-10-2019 11:26 PM
I would like to configure and test AAA on a Cisco ASA (e.g. 5505 or 5510).
1. Are there any further tools or server needed to use this feature? And do you have good configuration guides?
I have already tested a Cisco CDA. It was able to show the active directory users and their equivalent IP address.
2. Do you have a short explaination what kind of possibilities I have with this server/tool? Is it maybe usable for the mentioned AAA on the ASA?
Thanks in advance
Best regards
Solved! Go to Solution.
02-02-2016 05:27 AM
1. Yes you need a Radius server like Windows NPS or TACACS server like Cisco ACS/ISE.
2. CDA it's just a man in the middle, you will still need an AAA server: radius or tacacs (see no1).
02-02-2016 05:27 AM
