01-22-2015 09:27 AM - edited 03-10-2019 10:22 PM
I have a Empty startup-config file on my ubr7. I need to enable shh so i can ssh to the uBR without being physicaly next to it. Im am told i should enable Radius?. Does anyone have an idea how i can do this?
Solved! Go to Solution.
01-22-2015 12:08 PM
I have never used/configured that particular type of hardware but if it runs Cisco IOS then you can follow this:
http://www.thegeekstuff.com/2013/08/enable-ssh-cisco/
Check it out and let me know if you have any questions
Thank you for rating helpful posts!
01-22-2015 12:08 PM
01-22-2015 10:30 PM
It runs IOS cisco software, it should be configured just like any other router for shh.
