Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
3234
Beginner
confusing ACS 5.4 Alarm - no remote repository configured
The following message from ACS 5.4.0.46 is confusing me:
"Configure Remote Repository under Purge Configuration which is used to take a backup of data before purge."
cause it is configured:
and it also seems to work cause I got also messages that the purge is beginning and that it was successful.
What is the problem here?
6 REPLIES 6
Beginner
I'm actually having the same issue.  Same version of ACS.  My incremental backup schedule/frequencies are different, but otherwise I'm configured the same.  I was going to do a bug scrub and see if its a known bug.
Beginner
after manual compressing the info database the message disappears...
Beginner
Is this what you did?  Select Database Compress below  and then purge now to clear the error?
Beginner
Dear All
please update the status of the snap shot pasted becuase i am also facing same issue with it is keeps on saying same purging and how to get it disappear and why it is even there. can some one explain please
Beginner
Same problem with purging the database.
After a manual action, I do get an OK. But the next day the same warning.
Anyone find a solution?
Beginner
I had the same problem, ACS 5
I had the same problem, ACS 5.4 with latest patch 6 installed. I had to figure this out by myself and the solution was pretty simple.
Make sure you configure incremental backup before 4 AM as database purge is run every night at 4 AM. I configured it at 3 AM. Well, after you configure this via GUI you need to login CLI and stop/start Job Manager process:
# acs stop view-jobmanager
# acs start view-jobmanager
After that I got rid of those error messages and backups and database purges are working smoothly.
Cheers,
Kari
