CWA with WLC Firmware 7.0.228 and ISE 1.1.1
Does Cisco ISE central web authentication supports on WLC version 7.0.228 ?
My customer has many access points which are support only for firmware code 7.0.228.
Cisco ISE version 1.1.1
WLC 5500 Series but the existing access point is cannot support to 7.3
Pongsatorn Maneesud
2 Accepted Solutions
AFter checking both the ISE and the WLC release notes it looks as if CWA with Radius NAC support was introduced in 7.2.110
WLC -
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn7_2_110_0.html#wp784178
ISE -
http://www.cisco.com/en/US/docs/security/ise/1.1.1/compatibility/ise_sdt.html#wp55038
Hope that helps.
Tarik Admani
*Please rate helpful posts*
nspasov
Tarik is correct, you need 7.2.x and later to use CWA with ISE. Here is a general summary of features supported on ISE on 7.0 and 7.2 versions of code:
Scenarios                                                          WLC 7.0                                             7.2
802.1X Auth                                                     Yes                                                      Yes
802.1X + Posture                                            Yes                                                      Yes
802.1X + Profiling                                           Yes                                                      Yes
Web Auth + Posture                                       No *                                                   Yes
Web Auth + Profiling                                      Inventory only *                         Yes
Central Web Auth(CWA)                               No *                                                   Yes
Local Web Auth(LWA)                                   Yes                                                      Yes
5 Replies 5
martyn.rees
Level 4
Level 4
Which AP's do they have?
AP1230.
WLC -
ISE -
Hope that helps.
Tarik Admani
nspasov
802.1X Auth                                                     Yes                                                      Yes
Thank you so much.
