Contributor
Difference between authentication order and priority
Hi Experts,
While configuring for ISE I came across these two commands, authentication order and authentication priority.
The question is, if I have already specified the order with which authentication should happen, then what is the use of authentication priority command?
Which are the scenarios could these both commands could be leveraged?
Everyone's tags (1)
1 ACCEPTED SOLUTION
VIP Advisor
Re: Difference between authentication order and priority
3 REPLIES 3
VIP Advisor
Highlighted
Beginner
Authentication order define the sequence of authentication method used by the network device. The authetication priority dicates the prefered method. For example. auuthentication order dot1x mab authentication priority mab dot1x In this example the dot1x will be used first and then mab. Howver the prefered method will be the mab
Contributor
In my environment, I have the following commands set on the port, this way
authentication order dot1x mab
authentication priority dot1x
So, in this case, there is no other method specified for a fallback, what could be the result of this setup?
Everyone's tags (2)
