02-04-2019 10:35 PM - edited 03-11-2019 01:55 AM
Hi Experts,
While configuring for ISE I came across these two commands, authentication order and authentication priority.
The question is, if I have already specified the order with which authentication should happen, then what is the use of authentication priority command?
Which are the scenarios could these both commands could be leveraged?
Solved! Go to Solution.
02-04-2019 10:47 PM
02-04-2019 10:47 PM
02-04-2019 10:59 PM
02-06-2019 01:43 AM
In my environment, I have the following commands set on the port, this way
authentication order dot1x mab
authentication priority dot1x
So, in this case, there is no other method specified for a fallback, what could be the result of this setup?
