Distribution of Cisco NAC Agent & Compliance Module - Silent Installation
Hi folks,
Hope this finds you well...
My questionis the below;
How can i install the nac complaince module silently  with the nac agent msi package... it always prompt the user to install it manually. If user doesn't do it, he/she remains in unauthenticated VLAN?
Please advise...
Mubasher
Tarik Admani
Mubashir,
There is not a current xml setting where this can be done silently, however you should open a tac case or drive a feature enhancement through you Cisco resource. This should be a necessary feature for the nac agent.
thanks,
Tarik Admani
*Please rate helpful posts*
calverthall
Did you have any luck with this?  We are also seeking a way to deply (possibly by GPO) of the compliance module.
