Do I need Cisco ISE VM Part # L-ISE-VM-K9= for ESXi installation
alig.norbert
Level 4
Level 4
Hi there,
Do I need the L-ISE-VM-K9 license to install Cisco ISE on an ESXi ?
Actually, Cisco ISE can be downloaded with an Eval License for 90 days.
I know, ISE license (e.g. Base License) is needed.
Thanks a lot.
Greetings,
Norbert
Although the demo VM you're using is free, you're obliged to pay for L-ISE-VM-K9 when you move to a production model because it uses a licensed Oracle database underneath it.  You have to pay this for every instance of ISE that you run.  You will then need to buy the Wireless licenses as necessary for your number of devices.
6 Replies 6
Richard Atkin
Level 4
Level 4
If you want your deployment to last longer than 90 days... yes you need that part, along with the necessary licenses.
Also remember that if you're an existing ACS or NAC customer, you can use L-ISE-VM-M-K9 instead which will save you some money (plus other discounts available on Base and Adv Lics too)
Jatin Katyal
When you receive your new ISE appliance, evaluation (90-day) license is ALREADY installed. It allows you to perform initial setup of the system and carry on all necessary checks. This license is not created for live network usage, so you must change it to a regular license as soon as possible. This built-in license includes 1 base and 1 advanced license with 100 endpoints on each.
To check how much time do you have remaining on your evaluation license, go to:
Administration > System > Licensing > Current Licenses
Types of licenses you might want to install are:
Base;
Advanced;
Wireless.
It is also possible to have combined license, which is Base + Advanced.
Cisco Identity Services Engine Ordering Guide
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps5712/ps11637/ps11195/guide_c07-656177.html
Jatin Katyal
- Do rate helpful posts -
~Jatin
Thanks a lot.
I have installed the Cisco ISE on my lab ESXi and there is the EVAL license.
My question is, do I need to order L-ISE-VM-K9= and the wireless license (only for NAC on wifi) or only the wireless license to get a working ISE?
To me it seems that I don't need (technically) the L-ISE-VM-K9=, only the wireless one....
Greets,
Norbert
Thanks a lot,
Greets,
Norbert
Just in case you you would like to see the specification of each licence.
License Type
Features Supported
Deployment Type Supported
License Prerequisite
License Term(s)
Base License
AAA
Guest Provisioning
Link Encryption Policies
Wired
Wireless
VPN
Perpetual
Advanced License
Device Onboarding/Provisioning
Device Profiling and Feed Service*
Host Posture
Security Group Access
Integrated Vendor MDM Support*
Wired
Wireless
VPN
Base License
3- and 5-Year Terms
Wireless License
AAA
Guest Provisioning
Host Posture
Wireless
3- and 5-Year Terms
Wireless Upgrade License
Authentication/Authorization
Guest Provisioning
Device Profiling
Host Posture
Wired
Wireless
VPN
Wireless License
3- and 5-Year Terms
Cisco ISE Functionality-Based License Options
License Tiers (T)
Number of Endpoints Supported
Base License
Advanced 3-Year License
Advanced 5-Year License
Wireless 3-Year License
Wireless 5-Year License
Wireless Upgrade 3-Year License
Wireless Upgrade 5-Year License
100
100 Endpoints
L-ISE-BSE-100=
L-ISE-ADV3Y-100=
L-ISE-ADV5Y-100=
L-ISE-AD3Y-W-100=
L-ISE-AD5Y-W-100=
L-ISE-W-3UPG-100=
L-ISE-W-UPG-100=
250
250 Endpoints
L-ISE-BSE-250-
L-ISE-ADV3Y-250=
L-ISE-ADV5Y-250=
L-ISE-AD3Y-W-250=
L-ISE-AD5Y-W-250=
L-ISE-W-3UPG-250=
L-ISE-W-UPG-250=
500
500 Endpoints
L-ISE-BSE-500=
L-ISE-ADV3Y-500=
L-ISE-ADV5Y-500=
L-ISE-AD3Y-W-500=
L-ISE-AD5Y-W-500=
L-ISE-W-3UPG-500=
L-ISE-W-UPG-500=
1000
1000 Endpoints
L-ISE-BSE-1K=
L-ISE-ADV3Y-1K=
L-ISE-ADV5Y-1K=
L-ISE-AD3Y-W-1K=
L-ISE-AD5Y-W-1K=
L-ISE-W-3UPG-1K=
L-ISE-W-UPG-1K=
1500
1500 Endpoints
L-ISE-BSE-1500=
L-ISE-ADV3Y-1500=
L-ISE-ADV5Y-1500=
L-ISE-AD3Y-W-1500=
L-ISE-AD5Y-W-1500=
L-ISE-W-3UPG-1500=
L-ISE-W-UPG-1500=
2500
2500 Endpoints
L-ISE-BSE-2500=
L-ISE-ADV3Y-2500=
L-ISE-ADV5Y-2500=
L-ISE-AD3Y-W-2500=
L-ISE-AD5Y-W-2500=
L-ISE-W-3UPG-2500=
L-ISE-W-UPG-2500=
3500
3500 Endpoints
L-ISE-BSE-3500=
L-ISE-ADV3Y-3500=
L-ISE-ADV5Y-3500=
L-ISE-AD3Y-W-3500=
L-ISE-AD5Y-W-3500=
L-ISE-W-3UPG-3500=
L-ISE-W-UPG-3500=
5000
5000 Endpoints
L-ISE-BSE-5K=
L-ISE-ADV3Y-5K=
L-ISE-ADV5Y-5K=
L-ISE-AD3Y-W-5K=
L-ISE-AD5Y-W-5K=
L-ISE-W-3UPG-5K=
L-ISE-W-UPG-5K=
10,000
10K Endpoints
L-ISE-BSE-10K=
L-ISE-ADV3Y-10K=
L-ISE-ADV5Y-10K=
L-ISE-AD3Y-W-10K=
L-ISE-AD5Y-W-10K=
L-ISE-W-3UPG-10K=
L-ISE-W-UPG-10K=
25,000
25K Endpoints
L-ISE-BSE-25K=
L-ISE-ADV3Y-25K=
L-ISE-ADV5Y-25K=
L-ISE-AD3Y-W-25K=
L-ISE-AD5Y-W-25K=
L-ISE-W-3UPG-25K=
L-ISE-W-UPG-25K=
50,000
50K Endpoints
L-ISE-BSE-50K=
L-ISE-ADV3Y-50K=
L-ISE-ADV5Y-50K=
L-ISE-AD3Y-W-50K=
L-ISE-AD5Y-W-50K=
L-ISE-W-3UPG-50K=
L-ISE-W-UPG-50K=
100,000
100K Endpoints
L-ISE-BSE-100K=
L-ISE-ADV3Y-100K=
L-ISE-ADV5Y-100K=
L-ISE-AD3Y-W-100K=
L-ISE-AD5Y-W-100K=
L-ISE-W-3UPG-100K=
L-ISE-W-UPG-100K=
License Type
License SKU
Base License
L-ISE-BSE-[T]=
L-ISE-ADV3Y-[T]=
L-ISE-ADV5Y-[T]=
3-Year Wireless License
L-ISE-AD3Y-W-[T]=
5-Year Wireless License
L-ISE-AD5Y-W-[T]=
3-Year Wireless Upgrade License
L-ISE-W-3UPG-[T]=
5-Year Wireless Upgrade License
L-ISE-W-UPG-[T]=
Replace [T] with the appropriate license tier from Table 5 and 6.
Jatin Katyal
~Jatin
