06-17-2013 06:20 AM - edited 03-10-2019 08:33 PM
I'm trying to setup an open dot1x environment on C3750, with ACS 5.3 as RADIUS and Avaya as IP-phones.
When configuring on the interface
authentication port-control auto
authentication open
authentication host-mode multi-auth
the phone and PC can connect to their respective VLANs, obtain DHCP address and operate as expected. (Please note the switchport shows up as authenticated/authorized if the device has a dot1x supplicant on board, with valid credentials, but shows up as unauthorized if wrong credentials, or if no dot1x supplicant at all; however, I think this is normal behavior of the switchport).
Now, if the ACS is unreachable, the PC can still connnect to its VLAN and proceed, but the phone stays stuck in dot1x authentication.
My question : is this a misbehavior of the phone? I expect the phone to start with an EAPOL START, maybe switch and phone will subsequently exchange an 'identity request/response' but as the switch has no ACS in its backend, the process stops there, in other words, the phone will never be challenged for its credentials. I would expect the phone from then on to consider itself as authenticated and proceed 'just like it would proceed if authenticated, i.e. DHCP etc.
Nevertheless the phone seems to 'stay stuck' in its dot1x authentication procedure.
I don't expect that coding an authentication event server-dead action authorize ;... will unblock the phone's supplicant in this case of an already open dot1x port configuration.
Thanks for any clarification.
##### important update #####
From dot1x debug on the switch, it appears the phone sends each minute an EAPOL-start, triggering a EAPOL_Request_Identity (sw to phone) and EAPOL_Resp_Identity (phone to sw) and finally an EAPOL_FAIL code 4 (sw to phone). This last message does cause the phone to quick its dot1x process, it simply iterates on this sequence by reissuing EAPOL-start. Unlike the PC behind, which proceeds after the FAIL, considering itself as being authorized to the port (and the switch accepting, as we are in Open dot1x).
When now adding to the switchport
auth event server dead action authorize voice
auth ............................................................ vlan <native vlan>
the switch replies with an EAPOL code 4 - (auth) FAIL immediately. Again, the PC quits dot1x procedure and proceeds considering itself as authorized. And the phone continues sticking to dot1x EAPOL-start.
May we suspect here a 'bug' in the Phone, and should it stop further dot1x attempts (EAPOL-start) as soon as an EAPOL-Fail is received?
07-04-2013 06:52 AM
Hi Jan,
usually a voice vlan needs to be configured on the switchport. The phone starts in the access vlan and if authentication is ok the switch puts the Phone into a voice domain. On ACS you must configure device-traffic-class = voice.
Are you using a CISCO-Phone. Only Cisco-Phone send via CDP that a PC is disconncet. With a NON Cisco Phone the session remains forever. That is the reason that PC can go in working without a connection to ACS
sh authentication session
a good documentation:
07-04-2013 07:41 AM
Hi can you send your port configuration?
Sent from Cisco Technical Support Android App
07-04-2013 10:17 PM
aaa new-model
aaa authentication dot1x default group radius
aaa authorization network default group radius
dot1x system-auth-control
interface FastEthernet0/1
description Telefonport mit PC
switchport mode access
switchport voice vlan 24
speed 100
duplex full
authentication event fail action next-method
authentication host-mode multi-domain
authentication order dot1x mab
authentication timer inactivity server
authentication violation replace
mab
dot1x pae authenticator
dot1x timeout tx-period 1
dot1x max-req 3
dot1x max-reauth-req 1
spanning-tree portfast
ip radius source-interface Vlan311
radius server ACS_Pri
address ipv4 1.1.1.1 auth-port 1645 acct-port 1646
timeout 3
key 123
On ACS
Policy Elements/Authorization and Permissions/Network Access/Authorization Profiles
Create a Profile VOICE and select under Comon Task "Voice VLAN from unused to static. Then you can see
Yes (device-traffic-class=voice).
Thats it
07-04-2013 09:38 AM
Have you configured dot1x critical eapol?
