downloadable ACL failing on uauth..... PLEASE HELP!!!
dave.jones
Hello.
I am trying to get DACL's working on my FWSM (2.3(3)) From ACS 4. The users authentication is passes through to an RSA 6.1 token server. The user authenticates fine, however the ACL is not downloading.
The bebug shows the following as the user authenticates:
alloc_rip 0x1ec7670
new request 0x345 --> 0 (0x1ec7670)
no user or password - start from getuser
add_req 0x1ec7670 session 0x345 id 0
RADIUS_GET_USER
radius mkreq: 0x345
old request 0x345 --> 0 (0x1ec7670), state 1
wait user - new user testuser. get pass
RADIUS_GET_PASS
radius mkreq: 0x345
old request 0x345 --> 0 (0x1ec7670), state 3
wait pass - pass '***'. make request
RADIUS_REQUEST
radius.c: rad_mkpkt_authen
attribute:
type 1, length 10, content:
attribute:
type 4, length 6, content:
attribute:
type 5, length 6, content:
attribute:
type 26, length 33, content:
Vendor ID 0 0 0 9, type=1, len=27:
send pkt 192.168.1.1/1645
rip 0x1ec7670 state 7 id 0
rip 0x14190a0
: chall_state ''
: state 0x7
: timer 0x0
: reqauth:
fb 18 71 56 d7 c4 ad e2 73 30 a9 2e cf 5c 65 3a
: info 0x345
session_id 0x345
request_id 0x0
user 'testuser'
response '***'
app 23
reason 2
skey 'key'
sip 192.168.1.1
type 1
rad_procpkt: ACCEPT
attribute:
type 26, length 61, content:
Vendor ID 0 0 0 9, type=1, len=55:
attribute:
type 25, length 31, content:
RADIUS_REQUEST
attribute:
type 1, length 27, content:
attribute:
attribute:
attribute:
rip 0x14190a0
: chall_state ''
: state 0x7
: timer 0x0
: reqauth:
: info 0x345
session_id 0x345
request_id 0x0
user '#ACSACL#-IP-TEST-443f6681'
response '***'
app 23
reason 2
skey 'key'
sip 192.168.1.1
type 1
rad_procpkt: REJECT
abort request 0x345 (0)
RADIUS_DELETE
remove_req 0x1ec7670 session 0x345 id 0
free_rip 0x1ec7670
radius: send queue empty
As you can see the radius request is being rejected and ACS shows the following error in its failed attempts log:
"DACL request from device is not acceptable"
This is the is the configuration on the FWSM relevant to the problem.
access-list DMZ_VENDOR-IN extended permit tcp any host 172.25.25.25 eq telnet
access-list DMZ_VENDOR-IN extended permit tcp any host 172.25.25.25 eq https
access-list DMZ_VENDOR-IN extended deny ip any any
access-list UAUTH-ACL extended permit tcp any host 172.25.25.25 eq telnet
access-list UAUTH-ACL extended permit tcp any host 172.25.25.25 eq https
access-group DMZ_VENDOR-IN in interface DMZ_VENDOR per-user-override
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server RADIUS-GROUP protocol radius
aaa-server RADIUS-GROUP max-failed-attempts 3
aaa-server RADIUS-GROUP deadtime 10
aaa-server RADIUS-GROUP (AAA) host 192.168.1.1 KEY timeout 5
aaa-server RADIUS-GROUP (MSFC_FWSM) host 192.168.2.1 KEY timeout 5
aaa authentication match UAUTH-ACL DMZ_VENDOR RADIUS-GROUP
virtual http 172.25.25.25
virtual telnet 172.25.25.25
the ACS acl is very simple for testing purposes:
ACL NAME: test
permit ip any host 192.168.100.100
deny ip any any
the DACL is applied to the users profile.
Many thank for any help on this issue.
jhillend
You are probably running into bug CSCsc89235. This issues is resolved in ACS 4.0, but you have to upgrade your FWSM software to minimum version 2.3(3.13).
can you post the entire config of the module ?
GNT
The problem appears to be a bug in the FWSM code that we we're running 2.3(3)2 and also in 2.3(2). Version 2.3(4) appears to resolve this issue.
This is a result of the FWSM generating two RADIUS request packets with the same ID for the ACL instead of one. Subsequently the ACS server will reject the request for the ACL but still authenticate the user.
However ACS requires the access list to have a permit statement to the virtual telnet address to work correctly or it will produce the same ACS log entry.
