Dual SSID Onboarding with ISE 2.0
Javier Glaz
I am trying to configure a dual SSID onboarding scenario with ISE 2.0. I was following many guides, that make an authorization policy catching MAB and the Provisioning WLAN, and use a result of CWA.
In all the examples I found, the result uses Central Web Authentication, with the redirect ACL and in the Redirect it says "default".
However, when I try to do that in ISE 2.0, in the Redirect it says "Self Register" or "Sponsored Portal". When I try to use one of these options I get the guests portals, and I cannot go through the onboarding process.
Have someone configured this in ISE 2.0? Can someone guide me?
Javier
Jatin Katyal
You're going good. Continue with self-register and enter user guest credentials. Once you are done, you will be redirected to device registration portal. Endpoint MAC address will be pre-populated and you can enter the description if you wish. Accept the AUP if configured. Once accepted, you will be able to download Supplicant provisioning wizard. Let me know how far you reach.
~ Jatin
~Jatin
