Hi Darin,
The "5238 Endpoint authentication problem was fixed" message comes back when a client gets removed from suppression, because the client starts to authenticate again. You can disable suppression and you would see a different message saying "5434 Endpoint conducted several failed
authentications of the same scenario"
If you disable suppression, you could be increasing the load across the deployment by not identifying mis-configured clients that keep authenticating over and over with a problem.
If the issue is consistent, we should look why the user is failing authentication by taking debugs etc.
Kanwal
Note: Please mark answers if they are helpful.
