Ezvpn ISAKMP authorization (mode config) on IOS using ACS issue
Erik Ingeberg
I've set up ezvpn using DVTI for both hardware and software ezvpn clients on on a IOS router. Authentication authorization (mode config) is done with RADIUS towards ACS 4.2, and this is working fine.
In order to get this to work, I had to create users on ACS that have the same names as the ezvpn groups with password "cisco".
Users and ezvpn IOS NEM clients are getting authenticated and authorized correctly with the correct mode configuration. My problem is that I am able to log in with a vpn client using any group-name as username and the password "cisco".
Since the group-name is visible in the software client, and the password is always "cisco", it is very easy for unwanted users to get access (the enc_GroupPwd in the pcf file is very easily decrypted).
I have been trying to deny access to the username that is the same as the group-name, but then authentication fails.
Here is the relevant config for the software vpn client on the ezvpn server:
aaa authentication login acs group radius
aaa authorization network acs group radius
crypto isakmp policy 5
encr aes 256
authentication pre-share
group 2
crypto isakmp profile ezvpn-client
   self-identity address
   match identity group ezvpn-client
   client authentication list acs
   isakmp authorization list acs
   client configuration address respond
   virtual-template 30
crypto ipsec profile ezvpn-client
set transform-set tset
set reverse-route tag 10
set isakmp-profile ezvpn-client
interface Virtual-Template30 type tunnel
ip unnumbered Loopback0
ip ospf mtu-ignore
tunnel source x.x.x.x
tunnel mode ipsec ipv4
tunnel path-mtu-discovery
tunnel protection ipsec profile ezvpn-client
ip local pool ezvpn-client-pool x.x.x.1 x.x.x.254
ip access-list extended split
permit ip x.x.x.x x.x.x.x any
radius server acs
address ipv4 x.x.x.x auth-port 1812 acct-port 1813
key xxxx
ACS group config (both the "ezvpn-client" user and regular users are members):
cisco-av-pair:
ipsec:key-exchange=ike
ipsec:key-exchange=pre-shared
ipsec:inacl=split
ipsec:addr-pool=ezvpn-client-pool
ipsec:user-vpn-group=ezvpn-client
IETF attributes:
[006] Service-Type: Outbound
[064] Tunnel-Type: IP ESP
[069] Tunnel-Password: xxxx
Is there any way to stop the "ezvpn-client" user being able to connect using the well know password "cisco"?
Erik Ingeberg
I've tried using IOS CA rsa-sig for ISAKMP instead of pre-shared keys, and it works fine.
The problem is still the same though. Since the OU in the client certificate has to match the ezvpn group name (and corresponding ACS user), xauth is meaningless. There will always be a well known username who must have "cisco" as password. Anyone getting hold of a company laptop can get VPN access to corporate resources.
I'm starting to think that ISAKMP authorization with RADIUS is very insecure and should not be used under any circumstance.
Am I right in thinking that local ISAKMP authorization is the way to go for ezvpn?
