FMC and ISE integration for passive authentication
Hello all,
Is there a good guide that you can recommend for the configuration of both FMC and ISE to be able to perform passive authentication in Firesight using ISE as the identity source instead of using the AD agent?
Timothy Abbott
Please use one of the ISE and FMC integration guides at the below URL.  FMC uses pxGrid for idenitty sharing from ISE.  Then configure ISE to use PassiveID to integrate with AD.
ISE Design & Integration Guides
-Tim
Timothy Abbott
-Tim
