Beginner
HELP! Cisco ACS v 3.3
Greetings,
I have recently inherited and older ACS server. I am having trouble with certain ACS groups accessing resources witch they are not assigned to.
I've setup Windows Database and that works fine,  when assigning a specific AD group to an ACS defined group that work also.
But when I assign another windows Ad group to another ACS group, this group can access resources in other groups, which I don't want.
Is there something I am missing, I looked up and down, with no luck.
Any help is appriciated.
Thanks!
Everyone's tags (4)
9 REPLIES 9
Advocate
Mike,
Is the user a member of multiple groups in windows? Here is the following note within ACS 3.3:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_windows/3.3/user/guide/qg.html
Group Mapping Order
Cisco Secure ACS always maps users to a single Cisco Secure ACS group,  yet a user can belong to more than one group set mapping. For example, a  user, John, could be a member of the group combination Engineering and  California, and at the same time be a member of the group combination  Engineering and Managers. If there are Cisco Secure ACS group set  mappings for both these combinations, Cisco Secure ACS has to determine  to which group John should be assigned.
Cisco Secure ACS prevents conflicting group set mappings by assigning a  mapping order to the group set mappings. When a user authenticated by an  external user database is to be assigned to a Cisco Secure ACS group,  Cisco Secure ACS starts at the top of the list of group mappings for  that database. Cisco Secure ACS checks the user group memberships in the  external user database against each group mapping in the list  sequentially. Upon finding the first group set mapping that matches the  external user database group memberships of the user, Cisco Secure ACS  assigns the user to the Cisco Secure ACS group of that group mapping and  terminates the mapping process.
Clearly, the order of group mappings is important because it affects the  network access and services allowed to users. When defining mappings  for users who belong to multiple groups, make sure they are in the  correct order so that users are granted the correct group settings.
For example, a user, Mary, is assigned to the three-group combination of  Engineering, Marketing, and Managers. Mary should be granted the  privileges of a manager rather than an engineer. Mapping A assigns users  who belong to all three groups Mary is in to Cisco Secure ACS Group 2.  Mapping B assigns users who belong to the Engineering and Marketing  groups to Cisco Secure ACS Group 1. If Mapping B is listed first,  Cisco Secure ACS authenticates Mary as a user of Group 1, and she is be  assigned to Group 1, rather than Group 2 like managers should be.
Tarik Admani
*Please rate helpful posts*
Tarik Admani
Beginner
Hi Tarik,
The thing is the user is not a member of any other groups in windows or ACS...
I tried just using one user one group to one ACS group.. and I guess the user/group created first will always have access to groups that are created after?
Thanks again,
Mike
Advocate
Mike,
I wonder if the user is hitting the default group. Verify if this is the case in the passed attempts report, and then set the default group to no access and see if that changes your luck.
Tarik Admani
Tarik Admani
Beginner
hmm... I hav tried that still no luck...
two seperate users in sepearate groups (windows and ACS) have access to each others resources.
Advocate
Mike,
You are using a wildcard at the end of your groups "Mike,*" means Mike, or any NT group. Try removing the wildcard and see if that fixes your issue.
Tarik Admani
Tarik Admani
Beginner
this is a stupid questions, but how do I remove the wild card? there is no options to de select it or select it..
Advocate
You will have to delete the mapping and reenter it.
thanks,
Tarik Admani
Tarik Admani
Beginner
aggreed, but how do you not select the wildcard? it does it automatically...
I looked every where..
Mike
Highlighted
Advocate
I wish I had a 3.3 virtual machine that I can play with, and I know that it will be tough to get support for this since the product isnt supported anymore.
You can try to get in contact with TAC and ask this specific question and see how they can help you get your mapping straightened out.
Tarik Admani
Tarik Admani
