06-14-2014 12:52 AM - edited 03-10-2019 09:47 PM
How long it will take to upgrade Cisco ACS from 5.1.0.44 to 5.2.0.26.?
After typing below command i am not getting any output on my CLI but I am able to access ACS via GUI. Not sure what is happening?
application upgrade ACS_5.2.0.26.iso repository-name
Do you want to save the current configuration ? (yes/no) [yes] ?
YES
Please advice is it normal
06-14-2014 11:49 AM
I suspect the process is hung and will have to be terminated.
The ISO file is not the correct image for an upgrade. The ISO file is used to boot from and install a new server.
Please refer to the Installation and Upgrade Guide for 5.2 which directs us to use the following:
application upgrade ACS_5.2.0.26.tar.gz repository-name
The tar.gz file is available here (registered user with support contract only).
09-10-2014 05:08 PM
https://supportforums.cisco.com/discussion/11054936/problem-upgrading-csacs-1121-51-52
09-10-2014 09:00 PM
You need to use application upgrade ACS_5.2.0.26.tar.gz repository-name
Note If the backup data is huge in size, then extraction process might take a minimum of 1 hour to many hours.
