Huawei Switches
Ismael Dandashi
Hi all
did Huawei Swithces supporting Cisco ISE Profiling configuration ??
BR
Hi Ismael
I know it is not officially support by Cisco ISE Support  Matrix but that doesn't mean it wont work it simply means that Cisco has not tested functionality of those switches with their own product and  if you open a TAC case for such scenario they won't help you as it is not supported.
7 Replies 7
I want to know the same thing
Hi Ismael
I have integrated Cisco ISE with a test HUAWEI switch but only for 802.1X using EAP-FAST with posture assessment and it worked.
Didn't test Profiling for endpoints like IP Phones but as per HUAWEI team their switch supports standard profiling like (LLDP, SNMP and DHCP) but not Device sensor or CDP.
I will try and find that document for HYAWEI test lab with S5700 series switch with Cisco ISE and share it here which basically says everything is supported but it was a crafted test LAB but nobdy can assure that in real life.
Hi Guys
I found the interopertability of Huawei S series switches with Cisco ISE 2.0 Test LAB done with Tolly
kindly find it attached
With Regards
Naser
Hello Mohamed
thank you for your help, also i found one cisco doucment and not mentioned huawei Switches
https://www.cisco.com/c/en/us/td/docs/security/ise/2-3/compatibility/ise_sdt.html
Hi Ismael
Thanks @Mohamed Abd Elnaser Mohamed Mohamed Ali I reference this document, It's working fine. I'm looking for Huawei Wireless Controller and Cisco ISE guide. please help me if you have reference document.
rivalrudiansah
Hi Ismael,
I experienced the same thing as you, the parameter integrate Switch Huawei to Cisco ISE is it true that only creat radius and tacacs only?
