Import Network Devices into ISE 2.4 Authentication Protocol Required?
kevink707
I'm attempting to import network devices into ISE 2.4.
Following the template found in https://www.cisco.com/c/en/us/td/docs/security/ise/2-4/admin_guide/b_ise_admin_guide_24/b_ise_admin_guide_24_new_chapter_01001.pdf
The documentation says that Authentication:Protocol:String(6) is optional and the only valid value is "RADIUS".
My import is failing with the message: Failed Value for attribute Protocol is mandatory
Putting TACACS in that field is rejected.
Putting RADIUS in that field is accepted, however then I believe I need to manually edit each device to uncheck Radius (I have tens of thousands of devices so this is not very practical).
Any suggestions?
18 Replies 18
mumustha
Hi Kevin,
I might be late to the party.
I suspect that this could be caused due to the bug in ISE 2.3/2.4 described in the below link :
 https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvj13401
A workaround has been defined in the link which is to remove "FALS" under "Enable Multi Shared Secret:String(128)".
Hope that helps
I never EVER post anything on the Cisco forums, however this time I'm going to.
Why is isn't this the answer that's marked as the solution?!?!?!
Thank you sir!
I am glad I was able to inspire.
And please you may skip calling anyone “Sir” here.
Tim K
I had the same issue. I found a bug that has the fix action. I have pasted the results of it below for those that don't have a CCO account. Removing FALSE from the field listed below fixed the problem for me.
ISE "Failed Value for attribute Protocol is mandatory" when importing network device
CSCvj13401
Description
Symptom:
"Failed Value for attribute Protocol is mandatory" error message, when trying to Import Network device through CSV
Conditions:
having NAD that is configured for TACACS and was previously exported from ISE to a CSV
Workaround:
removing "FALS" under "Enable Multi Shared Secret:String(128)" and the import will work fine
