11-14-2014 06:43 AM - edited 03-10-2019 10:11 PM
ISE 1.2 (on vm) creates a backup file without error. I can use the file to restore a clean ISE installation (same release) without error. However, the ISE application server process is not running. "Reload" or "App Start" do not restart the ISE process. Including or not including the ade-os has no affect. I would apreciate any suggestions as to what might be preventing the ISE server proecess from running.
Solved! Go to Solution.
11-15-2014 07:34 PM
Hi Marvin,
Please make sure you also have the same version of patches on the clean ISE installation. I know from your statement you have same ISE 1.2 version but I would request you to check with the same version of patches on which the backup was taken.
Still if you have the same version of patches and not able to bring back the App server up and running , please attach ADE.log and catalina.out file, I will quickly take a look and suggest the next steps.
As per my knowledge and from your problem explanation , it is for sure you might be missing the patches.
Naresh
11-14-2014 01:59 PM
Did you change the time before?
11-15-2014 07:34 PM
Hi Marvin,
Naresh
11-16-2014 01:24 PM
After I installed the same patch version, everything worked perfectly.
Thank-you.
11-19-2014 04:07 AM
Few Data Restoration Guidelines listed here
http://www.cisco.com/c/en/us/td/docs/security/ise/1-2/user_guide/ise_user_guide/ise_backup.html#pgfId-1115992
