Generate the CA certificate from Microsoft Server Window 2008 R2, create a new web server certificate template, add the client authentication on the extension tab for EKU. Other option remain default setting.
I trying to import this certificate into Cisco Identity Service Engine it showing error. Well, the CSR is generated from this appliance somehow, key length is 2048 and SHA-256, save as .pem format.
The error it show as
"Certificate does not have required key usage (key usage bits for KeyEncipterment or KeyAgreement are missing)"
Please advice, thanks
Salah
