ISE DACL entry limitation on ASA VPN device?
Attila Horvath
Is there any limitation for DACL entries (or size) when Cisco ASA 5515 (ver 9.2(4) connect to  ISE 1.4 ?
We saw a 24 (!) entry limit in practice, but cannot found any  written value from cisco.
Is there?
Attila Horvath
Attila Horvath
Just to note, the trouble caused by a firewall (Zorp) between NAD and ISE node.
Now (we change the rule at firewall to a simplest one) we can see more than 64 entries sent by ISE to NAD.
Can you clarify the workaround was there a firewall between ISE and the ASA you were pushing the dacl to?
