ISE disk system IOPS
david.daverso
Level 4
Level 4
            Clarifying the ISE vmware appliance specifications, Can anyone provide me the ISE hardware requirement for disk system IOPS equivalent to an SNS-3495?
Thanks much,
David D.
shekharmore003
                 http://www.cisco.com/en/US/docs/security/ise/1.2/installation_guide/ise_vmware.html
Cisco ISE Appliance
3495
3415
Endpoint Supported
20,000
5,000
CPU
2 X Quad Core
2.4 GHz
Intel Xeon
1 X Quad Core
2.4 GHz
Intel Xeon
CPU Model
E5-2609
E5-2609
# of Cores per CPU
# of Threads per CPU
Total CPU's
8
Intel® Hyper-Threading Technology
No
No
Memory
32 GB
16 GB
Hard Disk
2 x 600GB 6Gb   SAS 10K RPM
Raid 0 + 1
1 x 600GB 6Gb   SAS 10K RPM
Operating System
64bit
64bit
Thanks much, shekharmore003, but the info you provided does not indicate a disk system IOPS.  An example of what I'm looking for is the Mobility Services Engine Data Sheet, where they specify IOPS for a low-end, standard, and high-end virtual appliances.
David D.
Cisco hasnt provided that in the documentation. It would best to open a tac case so they can have the BU provide a response.
In ISE 1.2 the minimum requirement is 50 Mbps, i know because I am getting the alarms where the minimum threshold is clearly labeled.
Hope this helps...(it would still be best to run this through tac for confirmation)
