Beginner
ISE distributed and guest portals
Hi Guys,
We are planning to deploy two ISE servers with sponsor portal and BYOD.
My question is how the sponsor portal and mydevices portal should work.
Can this configuration be achieved without using any load balancer for DNS?
Also how should I configure the CN and SAN in the public certificate?
Albert
1 ACCEPTED SOLUTION
Re: ISE distributed and guest portals
The best way is to use round robin DNS for a basic setup. Otherwide you can put PSNs behind a loadbalancer. check out http://cs.co/ise-scale resources and there is a link to BRKSEC-3432 slides going over that.
https://community.cisco.com/t5/security-documents/ise-performance-amp-scale/ta-p/3642148#toc-hId-118574828
Also you can check out the F5 LB document for more details on implementation
https://community.cisco.com/t5/security-documents/how-to-cisco-amp-f5-deployment-guide-ise-load-balancing-using/ta-p/3631159
6 REPLIES 6
VIP Advisor
there is good documentation for reference  here : (let us know if you stuck any where while configuring ) ?
https://community.cisco.com/t5/security-documents/ise-guest-amp-web-authentication/ta-p/3657224
BB
*** Rate All Helpful Responses ***
Beginner
Hi Balaji,
Thanks for the link.
Unfortunately I don't see anything related to a distributed environment.
Albert
Highlighted
I would recommend looking at the Prescriptive Guest guide at http://cs.co/ise-guest and admin guide
They go over DNS, how the sponsor portal work with easy URL FQDN and DNS. My devices works similar. Every PSN will serve these portals.
examples:
https://www.cisco.com/c/en/us/td/docs/security/ise/2-4/admin_guide/b_ise_admin_guide_24/b_ise_admin_guide_24_new_chapter_01111.html#ID20
Using a sponsor portal
If you want to look at redundancy information, check out BRKSEC-3432 it has slides discussing. Load balancing for these portals as well.
http://cs.co/ise-training
Make sure you mark answers as helpful or solutions please
Beginner
sorry but I still don't get how this should work.
I have my sponsorportal pointing to one PSN. If this PSN goes down, what is the best way to change the DNS resolution?
Using a load balancer for DNS?
VIP Advisor
If the PSN have configured Failover Option, and other PSN Configured Same Entry for the portable it should be able to redirect to same
portal.
you need to Loabalance on the Portal side, if the one Web Server go down, another one should take over.
make sense ?
BB
