04-02-2019 12:25 PM
ISE guest wireless use case consumes a base license: that we know.
If the guest wireless use case now leverages any guest user type (IdentityGroup:Name equals User Identity Groups: GuestType_Contractor), is now a Plus license required?
thanks much,
David D.
Solved! Go to Solution.
04-03-2019 07:03 AM
04-02-2019 02:57 PM
Nope. EndpointIdentity Groups that you create yourself (or relate to GuestType) don't consume Plus licenses. Plus license only consumed when you use a Group that relates to Profiling (e.g. if device is an Apple device).
04-02-2019 05:14 PM
Hi Arne,
Thanks much for your reply. You are correct. However, my particular use case leverages IdentityGroup:Name (as described in the ISE Guest Prescriptive Deployment Guide) and in this case, Plus licenses ARE expected to be consumed. My reference is the note for Plus licenses in Table 1 of the new ISE Adminstrator guide. https://www.cisco.com/c/en/us/td/docs/security/ise/2-4/admin_guide/b_ise_admin_guide_24/b_ise_admin_guide_24_new_chapter_0110.html
This must be a new change; eh?
best regards,
David D.
04-03-2019 07:03 AM
