10-09-2012 11:55 PM - edited 03-10-2019 07:39 PM
does anybody know if Radius device administration authentication and authorization is possible with the actual ISE release? I know that TACACS will be available in future release.
Joerg
Solved! Go to Solution.
10-11-2012 12:12 AM
Yes it's possible according to "Ask the experts" forum :
https://supportforums.cisco.com/thread/2172532
"If you use RADIUS for device administration, ISE can be utilized using authorization policy elements that return Cisco av-pairs. But personally, I think ACS is currently superior to ISE for this task."
Anyway, I'm about to test "device admin" and "network access" simultaneously in the same switch with Radius and ISE.
Please rate if it helps
10-12-2012 08:49 AM
Yes you can use radius even in the ACS days for device administration, however command authorization is not a feature that works efficiently with radius.
If you are using IOS devices your authorization policy should send back the "cisco-av-pair=priv-lvl=15". Please consult the product documentaiton for a radius authentication and the radius av pair should be present in most guides. I know you can do this with IOS, NX_OS, WLC devce to name a few.
Tarik Admani
*Please rate helpful posts*
10-11-2012 12:12 AM
10-12-2012 01:01 AM
thanks for your feedback.
Please post the results of your tests when have done them.
Joerg
10-12-2012 08:49 AM
Tarik Admani
