ISE upgrade issue
David Niemann
Level 3
Level 3
Trying to upgrade from 1.1.1.268 patch 5 to 1.1.2.145.  It fails saying the package isn't correct format via GUI.  Tried via CLI and I see this in the logs.
Jan  3 18:25:42 oranetise02 debugd[2507]: [22327]: application:install cars_install.c[245] [<removed>]: Install initiated with bundle - ise-appbundle-1.1.2.145.i386.tar.gz, repo - Patches
Jan  3 18:25:42 oranetise02 debugd[2507]: [22327]: application:install cars_install.c[259] [<removed>]: Stage area - /storeddata/Installing/.1357237542
Jan  3 18:25:42 oranetise02 debugd[2507]: [22327]: application:install cars_install.c[263] [<removed>]: Getting bundle to local machine
Jan  3 18:25:42 oranetise02 debugd[2507]: [22327]: transfer: cars_xfer.c[54] [<removed>]: ftp copy in of ise-appbundle-1.1.2.145.i386.tar.gz requested
Jan  3 18:26:12 oranetise02 debugd[2507]: [22327]: application:install cars_install.c[272] [<removed>]: Got bundle at - /storeddata/Installing/.1357237542/ise-appbundle-1.1.2.145.i386.tar.gz
Jan  3 18:26:12 oranetise02 debugd[2507]: [22327]: application:install cars_install.c[282] [<removed>]: Unbundling package ise-appbundle-1.1.2.145.i386.tar.gz
Jan  3 18:26:52 oranetise02 debugd[2507]: [22327]: application:install cars_install.c[294] [<removed>]: Unbundling done. Verifying input parameters...
Jan  3 18:26:52 oranetise02 debugd[2507]: [22327]: application:install cars_install.c[316] [<removed>]: Manifest file is at - /storeddata/Installing/.1357237542/manifest.xml
Jan  3 18:26:52 oranetise02 debugd[2507]: [22327]: application:install cars_install.c[326] [<removed>]: Manifest file appname - ise
Jan  3 18:26:52 oranetise02 debugd[2507]: [22327]: application:install cars_install.c[364] [<removed>]:  Patch bundle contains patch((null))  for app version(1.1.2.145)
Jan  3 18:26:52 oranetise02 debugd[2507]: [22327]: application:install cars_install.c[367] [<removed>]: Patch  for application version (1.1.2.145) is not matching the installed app version
Jan  3 18:26:53 oranetise02 debugd[2507]: [22327]: application:install install_cli.c[691] [<removed>]: error message: Patch cannot be applied to the installed application version.
Jan  3 18:26:53 oranetise02 debugd[2507]: [22327]: application:install install_cli.c[694] [<removed>]: Error while Installing - Patch bundle: ise-appbundle-1.1.2.145.i386.tar.gz  Repository: Patches ErrorCode: -623 Jan  3 18:25:42 oranetise02 debugd[2507]: [22327]: application:install cars_install.c[245] [<removed>]: Install initiated with bundle - ise-appbundle-1.1.2.145.i386.tar.gz, repo - Patches
Tarik Admani
David,
You can only upgrade the ise node when its standalone mode and through cli. Please use the application upgrade command to do the upgrade.
Here is some reference material.
http://www.cisco.com/en/US/docs/security/ise/1.1.1/upgrade_guide/upg_standalone.html
Sent from Cisco Technical Support Android App
6 Replies 6
Tarik Admani
David,
Vivek Santuka
David,
You cannot upgrade to 1.1.2 from 1.1.1 patch 5. You will need to drop down to patch 3. Do apply patch 2 on 1.1.2 to get the fixes that came out in 1.1.1 patch 4 and 5.
You are saying I have to downgrade from 1.1.1 patch 5 to patch 3 and then upgrade to 1.1.2, then apply patch 2? That doesn't make sense.  I followed Tarik's advice and it worked fine, but I would like to know why you say that.  It was my understanding the patches are cumulative so patch 5 has all the previous patches included.
David,
ISE 1.1.2 was release before ISE 1.1.1 patch 4. So some fixes that went into patch 4 and 5 did not make it to 1.1.2. Patch 2 on 1.1.2 covers that gap.
Based on what you say I could see not upgrading from 1.1.1 patch 3 directly to 1.1.2, but if I was already running 1.1.1 patch 5 why would I not upgrade directly to 1.1.2 and then apply patch 2 for 1.1.2?
To avoid contratictory fixes. Essentially, with patch 5 you aply a fix. Upgrade to 1.1.2 removes it (or even worse case leaves orphaned files etc. since it does not know about the fix) and then patch 2 applies it back. It will work fine as long as the "fix" is exactly the same. That assumption can be wrong.
Even the release notes were made to reflect that an upgrade to 1.1.2 requires you to be at 1.1.1 patch 3.
