ISE web login Issue.
xuekai zhang
Hi all:
     Here is  the scenario.My ISE is a vmare version,and works normal,now here comes an issue, my computer can't login the ISE web interface.
The other computer can login the ISE web interface.
     I think it maybe the cert's issue,cause when I login the web interface,the website give me the vmare's cert, but I think It should be my AD's cert.
     Any help or suggestion will be appreciated.
Naveen Kumar
Level 4
Level 4
There is the problem in the browser  you are using. So please remove all the pre added certificate from your browser  and try to connect to ISE using HTTPS. ISE will issue a certificate to you. Add  this certificate and you will get the GUI of ISE.
(Remove certificate from browser:  tools --> options --> content --> certificates --> remove then  restart it.)
