08-12-2013 01:07 AM - edited 03-12-2019 05:42 PM
Hi, I'm using ISE 1.2 and WLC 7.4.100
OSX is able to do dot1x authentication, after that, we turned on the parellel and used windows with bridge mode.
and it was able to get on the internet. and I want it not to. Is there any way to prevent pralellel on the internet?
08-12-2013 09:24 PM
Are you seeing any additional auth attempts from the bridged mac address.
Sent from Cisco Technical Support Android App
08-12-2013 09:44 PM
No, it just goes to the internet.
I think WLC does not even know there is another PC behind PHYSICAL PC
08-12-2013 09:56 PM
Are you sure you are using bridged mode and not nat mode? It seems as if the wlc would have a dedicated client entry for each different mac address that associates the controller.
08-14-2013 05:17 PM
This link gives all the information of your query to block and allow internet through wireless bridge mode.
http://www.cisco.com/en/US/products/ps10315/products_tech_note09186a0080bba10d.shtml
