12-29-2010 12:58 PM - edited 03-10-2019 05:40 PM
Hello Guys,
I Have installed a Cisco ACS SE with version 3.3. I am trying configure it to sendo log to acs remote agent but it is not working. I installed acs remote agent and I enabled Logging service during installation. ACS SE appliance can communicate with remote agent but ACS can't write LOGs on the Remote Agent. If I look logg on ACS its OK but when I look Logs on Windows remote Agent there is nothing there. Anyone could help me?
Solved! Go to Solution.
12-29-2010 05:28 PM
hi,
Please try configuration of Remote logging as mentioned in the link:
Anisha
P.S.: ACS 3.3 is out of life and support. Please upgrade to the latest version.
12-29-2010 05:28 PM
hi,
Anisha
01-03-2011 04:04 AM
Hi Anisha,
Thanks for help. I will follow your advice and I will update to latest version. Anyway your link help a lot.
See You,
Fabiano
