Hi!
When I try to add Active Directory as an Identity Store, I received:
Connection test to 'jerico.lan.vusecurity.com' failed.
Further information on status:
- Can not resolve network address
From console nslookup:
nslookup lan.vusecurity.com
Trying "lan.vusecurity.com"
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 54233
;; flags: qr aa rd ra; QUERY: 1, ANSWER: 2, AUTHORITY: 0, ADDITIONAL: 4
;; QUESTION SECTION:
;lan.vusecurity.com. IN ANY
;; ANSWER SECTION:
lan.vusecurity.com. 3600 IN NS jerico.lan.vusecurity.com.
lan.vusecurity.com. 3600 IN SOA jerico.lan.vusecurity.com. hostmaster. 7 900 600 86400 3600
;; ADDITIONAL SECTION:
jerico.lan.vusecurity.com. 3600 IN A 192.168.1.137
jerico.lan.vusecurity.com. 3600 IN A 192.168.1.103
jerico.lan.vusecurity.com. 3600 IN A 192.168.1.128
jerico.lan.vusecurity.com. 3600 IN A 192.168.56.1
Received 167 bytes from 192.168.1.103#53 in 10 ms
acsbrou/admin# nslookup jerico.lan.vusecurity.com
Trying "jerico.lan.vusecurity.com"
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 47734
;; flags: qr aa rd ra; QUERY: 1, ANSWER: 4, AUTHORITY: 0, ADDITIONAL: 0
;jerico.lan.vusecurity.com. IN ANY
;; ANSWER SECTION:
Received 107 bytes from 192.168.1.103#53 in 0 ms
Whatever I try failes:
VU as the domain real
lan.vusecurity.com wich is the fqdn
jerico.lan.vusecurity.com hostname + fqdn
Also check clock and timezone, I just need to do a 1 hour manual adjustement to by on sync with AD.
acsbrou/admin# show clock
Sat Dec 14 07:41:51 ARST 2013
acsbrou/admin#
Any idea could help
Thanks!
