Highlighted
Beginner
Making ACS 5.3 work correctly with NCS
Hi All
I am trying to get the ACS 5.3 to work with NCS but cannot make it work correctly.
I have looked at this link -
http://www.cisco.com/en/US/products/ps6305/products_tech_note09186a0080b904a4.shtml
But this does not show how the ACS referencing AD groups would work when determining
which   custom attributes to use.
On the ACS 5.3 i have set up the following -
The ad is working and in        Users and identity stores/External identity stores/Active Directory then my AD test works fine.
I have set up the  Users and Identity stores/Identity Groups with appropriate ip s.
I have configured the Network Device Groups/Network Devices and AAA Clients with the ip address and Authenication optionsA
In Policy Elements/Authorisation and Permissions/device administration/shell profiles
I have creeated a shell  profile called network shell pro
which das a common tasks of def priv = 0 and max priv = 15
Custom attributes of the following -
role0     Mandatory         Admin
task7    Mandatory         Administration Menu Access
task69   Mandatory        Home menu access
virtual-domain1   Mandatory  CRUK
task80    Mandatory      License Check
virtual-domain0    Mandatory   ROOT-DOMAIN
IN Access Policies/Access services/Default Device Admin
i have identity and Authorisation ticked -
identity = AD1
Authorisation =
name      AD1:External groups          Compound Condition   NDG:Device Type                          NDG:Location time/date identity group shell profile
Rule-1      ANY                                AD Group                   In all device types:Cisco Prime     Any                   any        any               network shell pro
Now i can get into the NCS but i do not see any of the administration buttons on NCS - so
this means the custom attributes are not working.
Any ideas on why this is not working - i shouldnt need a user for this on the ACS as its using AD !!!
Thanks in Advance
Steve
Everyone's tags (5)
3 REPLIES 3
Beginner
Re: Making ACS 5.3 work correctly with NCS
Hello
Please find the attached. I added all in the the screen shots to make it work.
Beginner
Hi usnetworkguy. Can you make that rft a .txt document ?  Having same issue.
Beginner
role0=Admin
task0=Users and Groups
task1=Audit Trails
task2=TACACS+ Servers
task3=RADIUS Servers
task4=Logging
task5=License Center
task6=Scheduled Tasks and Data Collection
task7=User Preferences
task8=System Settings
task9=View Alerts and Events
task10=Email Notification
task11=Delete and Clear Alerts
task12=Pick and Unpick Alerts
task13=Configure Controllers
task14=Configure Templates
task15=Configure Config Groups
task16=Configure Access Points
task17=Configure Choke Points
task18=Monitor Controllers
task19=Monitor Access Points
task20=Monitor Clients
task21=Monitor Tags
task22=Monitor Security
task23=Monitor Chokepoints
task24=Mesh Reports
task25=Client Reports
task26=Performance Reports
task27=Security Reports
task28=Location Server Management
task29=View Location Notifications
task30=Maps Read Only
task31=Maps Read Write
task32=Client Location
task33=Rogue Location
task34=Planning Mode
task35=Ack and Unack Alerts
task36=Migration Templates
task37=Configure Spectrum Experts
task38=Monitor Spectrum Experts
task39=Virtual Domain Management
task40=Scheduled Configuration Tasks
task41=Configure ACS View Servers
task42=Auto Provisioning
task43=RRM Dashboard
task44=Voice Audit Report
task45=Config Audit Dashboard
task46=High Availability Configuration
task47=Health Monitor Details
task48=Configure WIPS Profiles
task49=Global SSID Groups
task50=WIPS Service
task51=Configure Lightweight Access Point   Templates
task52=Configure Autonomous Access Point   Templates
task53=Guest Reports
task54=Configure Ethernet Switch Ports
task55=Configure Ethernet Switches
task56=Device Reports
task57=Network Summary Reports
task58=Compliance Reports
task59=Report Launch Pad
task60=Run Reports List
task61=Saved Reports List
task62=Report Run History
task63=Monitor Interferers
task64=CleanAir Reports
task65=Automated Feedback
task66=TAC Case Attachment Tool
