Beginner
Migrate from ACS 1121 Appliance ACS 5.6 to VM ACS 5.8
Our 1121 Appliance is EOL. The decision was made not to migrate to ICS, at this time. We decided to migrate from the 1121 appliance ACS 5.6 to VM ACS 5.8. I have been searching for documents on best practices for doing this but have had little success Can someone provide info on this? Thanks
Everyone's tags (1)
1 ACCEPTED SOLUTION
Re: Migrate from ACS 1121 Appliance ACS 5.6 to VM ACS 5.8
Hi Doug,
You can follow the same instructions to migrate from AS 1121 to 34xx appliance by doing a backup and restore. Please remember, if you have multiple ACS servers, and choose to upgrade then you need to do it in a certain order as outlined in the doc.
Installation and Upgrade Guide for Cisco Secure Access Control System 5.8 - Upgrading the Cisco Secure Access Control Sy…
-Krishnan
1 REPLY 1
Hi Doug,
-Krishnan
