Monitor the creation of monitor sessions
lachlanpeters
Hi All,
I am needing to find away to monitor if a monitor sessions is created/deleted or change.
Is there anyway that you know of to see that detail
Panos Kampanakis
What platform are you using?
You could monitor for syslog id "302013: Built {inbound|outbound} TCP connection_id..." and "302014: Teardown TCP connection id...".
If you are using an ASA then after version 8.2 you can use netflow to collect connection statistics with a neftlow collector.
I hope it helps.
PK
It is on a switch ( 2960, 3560 and 3750. All IOS at most 1 year old)
I am looking basically if anyone enters "monitor session........" a syslog event is triggered
Lachlan
