MSFT CA vs. ASA built-in CA
CSCO12052693
I'm trying to setup VPN users to authenticate with digital certificates as part of 2 factor authenication. With a 5510 (upgrading to 5515) with access to Microsoft 2008r and 2012, Which would be a better fit the Microsoft service or the built-in CA service on the ASA? (needed for less than 25 VPN users but would like setup for growth.)
Jeremy
fashour
You would get more benefit out of MS-CA. backups, scale, management, flexibility to use for other purposes if needed (wireless/dot1x for example) are some of the advantages. The Local CA works however and is considered more cost effective.
FaDi
fashour
FaDi
Thanks for the reply. Think I'll try out MS-CA.
