Nexus 1000v trustsec enforcement.
Sylvain Tdsc
I set up a lab with a nexus 1000v and Cisco ISE 2.3 and I would like to use trustsec to apply policies (RBACL) on the nexus 1000v to block or allow traffic between VMs.
My setup seems good, when I assign an SGACL in the matrix, I can see on the nexus 1000v that it is pushed but the enforcement doesn't seems to work.
here is a sample of my configuration :
!Command: show running-config port-profile VLAN102
version 5.2(1)SV3(2.8)
port-profile type vethernet VLAN102
  switchport mode access
  switchport access vlan 102
  cts manual
    policy static sgt 102 trusted
    role-based enforcement
  no shutdown
  state enabled
  vmware port-group
!Command: show running-config port-profile VLAN106
port-profile type vethernet VLAN106
  switchport access vlan 106
  cts manual
    policy static sgt 106 trusted
  no shutdown
  state enabled
  vmware port-group
and an example of RBACL pushed to the nexus 1000v and who is not working :
N1000V_PRI# sh cts role-based policy
sgt:102
dgt:106 rbacl:Deny_ALL
        deny ip
Althought my Vlans 102 can still communicate with Vlan 106.
And if I check the counters I can see that all my traffic hit only the permit rule (which is the default rule) :
N1000V_PRI# sh cts role-based counters
RBACL policy counters enabled
Counters last cleared: Never
Counters last updated on 11/17/2017 at 03:49:07 AM:
rbacl:Deny_ALL
        deny ip                                         [0]
rbacl:Deny_ICMP
        deny icmp                                       [0]
        permit ip                                       [0]
rbacl:Permit IP
        permit ip                                       [1806]
Any ideas of what I did wrong or is there something I missed to activate enforcement on the Nexus 1000v ?
Thank you.
I figured out what was the "problem" with a packets capture.
Inter-vlan routing is made with a 3750G in my lab, which mean that the communication between my two VMs goes :
VM in VLAN102 > N1000v > 3750G > N1000v > VM in VLAN106.
Since the 3750G doesn't support SGT InLine Tagging the Nexus 1000v has no clue about the SGT when the packet come from the 3750G.
To conclude I can do enforcement between VMs that are in the same Vlan and connected to differents port-profiles with differents SGTs but if you want to do enforcement between VLANs with the nexus1000v, you have to add a Layer 3 device compatible with trustsec services.
5 Replies 5
hslai
Moved to TrustSec space.
jeaves@cisco.com
Check 'cts device tracking' is configured, 'show cts device tracking'.
Also see if your endpoints are tracked, for example:
Kernow-N1kv# show cts ipsgt entries
Interface       SGT      IP ADDRESS   VRF/VLAN      Learnt
Vethernet2      11       10.10.6.20   vlan:60       Device Tracking
Vethernet3      14       10.10.6.21   vlan:60       Device Tracking
Vethernet4      19       10.10.5.22   vlan:50       Device Tracking
Hello Jeaves,
Yes Device tracking is enabled and my VMs appears in the list :
N1000V_PRI# sh cts ipsgt entries
Vethernet4      106      10.10.106.85        vlan:106      Device Tracking
Vethernet5      106
Vethernet6      106
Vethernet7      106
Vethernet8      106      10.10.106.50        vlan:106      Device Tracking
Vethernet9      102      10.10.102.6         vlan:102      Device Tracking
I guess you must have the right license otherwise I don't think you would have got this far.
Advanced Services License is required.
I notice your port profile is configured with tags in decimal. As far as I know, these should be entered in hex as described here:
policy static sgt tag [trusted]: Configures a static authorization policy. The tag argument is a hexadecimal value in the format 0xhhhh. The range is from 0x2 to 0xffef. The trusted keyword indicates that traffic coming on the interface with this SGT should not have its tag overridden.
In your case:
  cts manual
    policy static sgt 0x66
  cts manual
    policy static sgt 0x6a
As you are connecting to hosts then the trusted attribute is not needed.
