Beginner
Nexus 7000 and ACS AV-PAIRS
Dear all,
I'm having an issue with TACACS+ AAA setup with a Nexus 7000 running 4.2(2a) and ACS 4.2. I've added the av-pair string of
shell:roles="network-operator vdc-admin" into the TACACS+ settings under the group custom attributes. When I log in I the login hangs
waiting for the custom attribute pair to respond back the switch which it doesn't seem to do and it then dumps me into vdc-operator role and not the
vdc-admin role.
Can any one give me any additional pointers?
Thanks in advance,
Col
Everyone's tags (3)
8 REPLIES 8
Beginner
Re: Nexus 7000 and ACS AV-PAIRS
All,
Just for reference we've fixed this. The based VDC always seemed to honour the PRIV 15 under the ACS group and gave you network-admin, the correct syntax for vdc-admin passthrough on the av-pair is:
shell:user=admin-vdc
That's all you need.
Col
Beginner
Colin,
I saw your post and figured I would give you a shout.  I have a client with a 7K installed.  We are running ACS 4.2 and all network equipment is functioning with the exception of the 7K.
We keep getting:
TACACS-3-TACACS_ERROR_MESSAGE: All servers failed to respond
Do you have a sample of your config for your 7K?  Did you have to do anything special in ACS for it to talk to the 7K?  Been beating my head on this for a few weeks and the Cisco Config guides don't solve my issue.  Follow them to a tee and still does not work.
Josh
Beginner
I am also getting this message repeatedly on my NX5000, although the authentication and authorization are working fine. Will appreciate any clues. thanks
%TACACS-3-TACACS_ERROR_MESSAGE: All servers failed to respond
Beginner
Hi Colin Chambers,
Can you please post the error and the current config for tacacs on NX7000.
Beginner
Hi Colin,
Can u help me to resolve the issue of ACS 4.2 with nexus 7k. wat configuration u did in ACS ?
Veer Pratap Singh
Beginner
My server was sending minor version 0 instead of 1 when I saw the same error message.
Brian Holmes
Verizon
Beginner
Highlighted
Beginner
One other thing I had to send was TACACSPLUS-Priv-Level = ROOT
which by the way was not in any manual.
Brian Holmes
Verizon
