11-23-2015 04:35 PM - edited 03-10-2019 11:15 PM
I am perplexed by my issue. I have one switch out of 9 that cannot authenticate with our TACACS server. The configurations are the same as every other switch, yet when I try to log in using the TACACS+ account, access is denied. Here is the configuration for the AAA/TACACS on the switch.
aaa new-model
aaa authentication login default group tacacs+ local
aaa authorization console
aaa authorization exec default group tacacs+ local
tacacs-server host X.X.33.XX
tacacs-server key 7 ???????????
I have removed the aaa configuration and then reconfigured it along with the tacacs server information and no tacacs authentication. I have given the interface tacacs should use, but same outcome. Any ideas?
Thank you,
Robert
Solved! Go to Solution.
11-23-2015 05:11 PM
Robert,
Please make sure following
- Tacacs server is reachable from the switch and port 49 is not blocked.
- If this is layer 3 switch then make sure to setup ip tacacs source interface XXXX (Interface IP that is defined in tacacs server)
- Check secret key
If issue is still there then please get
debug aaa authentication
debug tacacs
~JG
11-23-2015 05:11 PM
Robert,
- Check secret key
debug tacacs
~JG
11-24-2015 09:44 AM
JG,
Thank you for your assistance. I thought about it this morning and I wasn't sure that I had even entered the ip tacacs source-interface command. I entered it this morning, and I turned on debug for aaa authentication and tacacs, so that I could see what was happening on the switch. I attempted to log in with my tacacs account and I was able to without an issue.
Thank you again for your help.
